주요 콘텐츠로 건너뛰기
iRobot Braava 320 Battery Replacement
필요한 것
  1. iRobot Braava 320 Battery  Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Battery  Replacement: 2 단계, 이미지 1/1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Battery  Replacement: 3 단계, 이미지 1/2 iRobot Braava 320 Battery  Replacement: 3 단계, 이미지 2/2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
bradley boardwine
회원 가입일: 02/28/17
222 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 회원
USFT-NANCE-S17S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
where do I get a new battery from?
j.svetlova - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 4,744
