소개
Although a cracked or broken body shell may not hinder the performance of your Braava, replacing it will help restore the cosmetic beauty of your device. It is a simple and straight forward replacement, requiring only four exposed screws to be removed.
필요한 것
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
다른 한 분이 해당 안내서를 완성하였습니다.
