주요 콘텐츠로 건너뛰기
iRobot Braava 320 Deck Plate Arms Replacement
필요한 것
  1. iRobot Braava 320 Deck Plate Arms Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Deck Plate Arms Replacement: 2 단계, 이미지 1/1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Deck Plate Arms Replacement: 3 단계, 이미지 1/2 iRobot Braava 320 Deck Plate Arms Replacement: 3 단계, 이미지 2/2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Deck Plate Arms Replacement, Body Shell and Control Panel: 4 단계, 이미지 1/1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Deck Plate Arms Replacement: 5 단계, 이미지 1/2 iRobot Braava 320 Deck Plate Arms Replacement: 5 단계, 이미지 2/2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Deck Plate Arms Replacement, Deck Plate Assembly: 6 단계, 이미지 1/1
    • With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
  7. iRobot Braava 320 Deck Plate Arms Replacement: 7 단계, 이미지 1/3 iRobot Braava 320 Deck Plate Arms Replacement: 7 단계, 이미지 2/3 iRobot Braava 320 Deck Plate Arms Replacement: 7 단계, 이미지 3/3
    • Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
    • Remove the two springs by gently lifting them up.
  8. iRobot Braava 320 Deck Plate Arms Replacement: 8 단계, 이미지 1/1
    • Flip the device over and remove the deck plate assembly cover by lifting it up.
  9. iRobot Braava 320 Deck Plate Arms Replacement: 9 단계, 이미지 1/1
    • Pull the arms together by lifting them up and to the center.
    • With the arms together. slide the deck plate up and over the arms until it is fully removed.
  10. iRobot Braava 320 Deck Plate Arms Replacement, Deck Plate Arms: 10 단계, 이미지 1/1
    • With the deck plate off, remove the three 10mm Phillips #2 screw
  11. iRobot Braava 320 Deck Plate Arms Replacement: 11 단계, 이미지 1/2 iRobot Braava 320 Deck Plate Arms Replacement: 11 단계, 이미지 2/2
    • Be careful when removing the arms, do not lose the springs located under the arms.
결론
Amroo
회원 가입일: 02/28/17
101 평판
안내서 1개 작성함
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 회원
USFT-NANCE-S17S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 610
