이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Without properly functioning wheels, the Braava will have a difficult time navigating. This will lead to inefficient sweeping or mopping. This guide will show how to replace the Braava's wheels.
필요한 것
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 한 개
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
