소개
The back shell of the iRobot Braava Jet 240 covers the device’s water tank. Therefore, in order to remove the water tank, the back shell must first be removed. Follow this guide to replace the back shell.
필요한 것
Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
Insert a Phillips #1 screwdriver through the screw holes.
Unscrew the two 9.7 mm screws.
거의 끝나갑니다!
결론
