소개
If the filter on your iRobot Braava Jet 240 needs to be replaced, follow this guide.
The filter is located between the tank cover and the tank. The filter catches any residue that is in the water, ensuring that the iRobot Braava Jet 240 only sprays clean water. If the filter collects too much dirt, it needs to be removed and cleaned. The filter could also tear, in which case it should be replaced.
다른 2명이 해당 안내서를 완성하였습니다.
