주요 콘텐츠로 건너뛰기
iRobot Braava Jet 240 Nozzle Replacement
필요한 것
  1. iRobot Braava Jet 240 Nozzle Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device off.
  2. iRobot Braava Jet 240 Nozzle Replacement: 2 단계, 이미지 1/2 iRobot Braava Jet 240 Nozzle Replacement: 2 단계, 이미지 2/2
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Nozzle Replacement, Mop Pad: 3 단계, 이미지 1/2 iRobot Braava Jet 240 Nozzle Replacement, Mop Pad: 3 단계, 이미지 2/2
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Nozzle Replacement: 4 단계, 이미지 1/3 iRobot Braava Jet 240 Nozzle Replacement: 4 단계, 이미지 2/3 iRobot Braava Jet 240 Nozzle Replacement: 4 단계, 이미지 3/3
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Nozzle Replacement: 5 단계, 이미지 1/1
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Nozzle Replacement, Front Shell: 6 단계, 이미지 1/2 iRobot Braava Jet 240 Nozzle Replacement, Front Shell: 6 단계, 이미지 2/2
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. iRobot Braava Jet 240 Nozzle Replacement: 7 단계, 이미지 1/2 iRobot Braava Jet 240 Nozzle Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Nozzle Replacement: 8 단계, 이미지 1/3 iRobot Braava Jet 240 Nozzle Replacement: 8 단계, 이미지 2/3 iRobot Braava Jet 240 Nozzle Replacement: 8 단계, 이미지 3/3
    • Carefully pull back on the front shell to remove it from the robot.
  9. iRobot Braava Jet 240 Nozzle Replacement, Nozzle: 9 단계, 이미지 1/2 iRobot Braava Jet 240 Nozzle Replacement, Nozzle: 9 단계, 이미지 2/2
    • Pull the nozzle assembly away from the body of the robot.
  10. iRobot Braava Jet 240 Nozzle Replacement: 10 단계, 이미지 1/3 iRobot Braava Jet 240 Nozzle Replacement: 10 단계, 이미지 2/3 iRobot Braava Jet 240 Nozzle Replacement: 10 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the 16 mm screw that holds the nozzle in place.
  11. iRobot Braava Jet 240 Nozzle Replacement: 11 단계, 이미지 1/1
    • Continue unscrewing the 16 mm screw until it comes out of the nozzle.
  12. iRobot Braava Jet 240 Nozzle Replacement: 12 단계, 이미지 1/3 iRobot Braava Jet 240 Nozzle Replacement: 12 단계, 이미지 2/3 iRobot Braava Jet 240 Nozzle Replacement: 12 단계, 이미지 3/3
    • Gently remove the tube from the nozzle.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Claire Franz
회원 가입일: 02/10/20
2,772 평판
안내서 7개 작성하였습니다
Cal Poly, Team S22-G2, Regan Winter 2020 Cal Poly, Team S22-G2, Regan Winter 2020 회원
CPSU-REGAN-W20S22G2
5 회원들
안내서 12개 작성하였습니다
댓글 12개
Hi Claire! I have a guide for unclogging the pump after a prolonged storage duration, and I wish to use your photos and guide for the first half of the guide. Shall we collaborate on writing that guide?
Thanks!
Matt S - 답글
Hi Matt! That’s a great idea. It sounds like you’re wanting to use this Nozzle Replacement guide as a prerequisite guide for your guide on the pump, is that correct?
Claire Franz -
If you’re like me and you have issues with the pump after a long duration in deep storage, there could be an issue with the tube within the pump where the pump would clog itself.
Follow all the steps to this guide, then look for the clear tube connected to the nozzle tube. You will see a circular black disk, with two metal pins and 2 metal wires on it. In the middle, there should be a Philips head screw. Use your #1 Screwdriver to unscrew the screw,
Next, carefully pull up on that black disk assembly. You will slowly pull up the tube. Be careful not to pull it too hard and puncture the tube.
Look at the clear tube. If you have stored it for too long, it is highly likely that the two white rollers on the black disk assembly have caused indents on the tube, causing a clog. Remedying that clog should be easy, gently press down on the tube on where the clog is, perpendicular to the clog. You should hear a little pop once the clog is unblocked. Repeat for the second clog, if required.
Matt S - 답글
Following that, reassemble the machine going in reverse.
This problem should be a known issue for most Braava Jet 240s. There is no safe parking location for the pump for long storage, and the prolonged pressure on the clear tube will cause it to clog eventually.
Hope this helped and saved you from buying another Braava Jet.
Matt S -
IRobot doesn’t sell nozzle replacement.
Hiroko Takikita - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 129
전체 시간: 8,959
