주요 콘텐츠로 건너뛰기
iRobot Looj 120 Remote Circuit Board Replacement
필요한 것
  1. iRobot Looj 120 Remote Circuit Board Replacement, Removing Screws: 1 단계, 이미지 1/1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Remote Circuit Board Replacement, Locate Circuitry: 2 단계, 이미지 1/1
    • Disconnect circuit board from power leads, and install new circuit board.
결론
Joshua
회원 가입일: 10/24/14
631 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Where can you get the replacement circuit board for the remote control?
Landon Lewis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 282
