주요 콘텐츠로 건너뛰기
iRobot Mint 4200 Wheel Motor Replacement
필요한 것
  1. iRobot Mint 4200 Wheel Motor Replacement, Remove Battery: 1 단계, 이미지 1/1
    • Remove the 4mm flathead screw on the battery cover.
  2. iRobot Mint 4200 Wheel Motor Replacement: 2 단계, 이미지 1/1
    • Pull out the battery and unplug the wires.
    • The nylon tip pliers can help you get a better grip on the battery plug.
    • Do not pull on the wires.
  3. iRobot Mint 4200 Wheel Motor Replacement, Wheel Motor Covers: 3 단계, 이미지 1/1
    • Eight Phillips screws are located underneath the stickers.
    • Carefully cut around the 8 screw holes using an X-acto knife or razor blade to reveal the screws.
    • Remove the screws with a #2 Phillips screwdriver.
  4. iRobot Mint 4200 Wheel Motor Replacement: 4 단계, 이미지 1/1
    • Separate wheel motor lid and set aside.
  5. iRobot Mint 4200 Wheel Motor Replacement, Cleaning Pad: 5 단계, 이미지 1/1
    • Remove cleaning pad.
    • The cleaning pad is magnetic and will pull right off with a little force.
  6. iRobot Mint 4200 Wheel Motor Replacement, Separating Top Case: 6 단계, 이미지 1/1
    • Remove four #2 Phillips screws.
  7. iRobot Mint 4200 Wheel Motor Replacement, Separate Case: 7 단계, 이미지 1/1
    • With the device upside down, pull up to separate the bottom from the top cover.
  8. iRobot Mint 4200 Wheel Motor Replacement, Wheel Removal: 8 단계, 이미지 1/1
    • Locate the three arrows on each wheel.
    • Insert metal spudger at arrow locations to pop off the wheel covers.
  9. iRobot Mint 4200 Wheel Motor Replacement: 9 단계, 이미지 1/1
    • Use blunt nose pliers to remove circlip.
    • Once clip is removed you can pull the wheel off in an outward motion.
    • Wedge one side of the pliers between the clip opening and carefully pry upwards.
  10. iRobot Mint 4200 Wheel Motor Replacement, Motor Mount: 10 단계, 이미지 1/1
    • Remove two #1 Phillips screws.
    • Pull off sprocket.
  11. iRobot Mint 4200 Wheel Motor Replacement, Remove Counterweights: 11 단계, 이미지 1/1
    • Remove four #2 Phillips and lift off retainer.
    • Pull out all weights and set aside
    • Keep weights stacked together so they do not get mixed up.
  12. iRobot Mint 4200 Wheel Motor Replacement, Unplug Motor: 12 단계, 이미지 1/1
    • Unplug the motor.
    • Do not pull on the plug as this can cause damage.
  13. iRobot Mint 4200 Wheel Motor Replacement: 13 단계, 이미지 1/1
    • Using the blunt nose pliers, peel up the adhesive and feed the wires with adhesive through the opening.
  14. iRobot Mint 4200 Wheel Motor Replacement, Pull the Motor Out: 14 단계, 이미지 1/1
    • Flip the unit over and pull the motor out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Blake Klein
회원 가입일: 01/29/17
70,583 평판
안내서 50개 작성하였습니다
댓글 2개
Nice! Very helpful.
Evan Noronha - 답글
Popping the wheel covers as shown breaks the small hooks that hold the wheel cover on. You need to rotate the cover clock wise to release them. There probably is a special tool that uses the small impressions in the cover.
wayne peterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 1,708
