이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
Remove the wire brush by grabbing it by the yellow plastic part of the brush.
Pull the brush upwards until it comes out.
Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
Pull the brush upwards until it dislodges.
다른 2명이 해당 안내서를 완성하였습니다.
