주요 콘텐츠로 건너뛰기
iRobot Roomba 551 Battery Replacement
필요한 것
  1. iRobot Roomba 551  Battery Replacement, Side Brush: 1 단계, 이미지 1/1
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - 답글
  2. iRobot Roomba 551  Battery Replacement: 2 단계, 이미지 1/1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: 3 단계, 이미지 1/1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: 4 단계, 이미지 1/1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: 5 단계, 이미지 1/2 iRobot Roomba 551  Battery Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: 6 단계, 이미지 1/1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: 7 단계, 이미지 1/2 iRobot Roomba 551  Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Deborah Newberry
회원 가입일: 01/23/14
623 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 회원
CPSU-REGAN-W14S13G14
4 회원들
안내서 19개 작성하였습니다
댓글 한 개
Thank you Deborah!
James - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 28
30일 전: 115
전체 시간: 9,700
