소개
The battery is quite simple to replace in a Roomba, and only requires removing the side brush and bottom plate before it can be accessed.
필요한 것
Lift and remove the old battery by pulling the tabs on both sides.
Gently replace with a new battery.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - 답글
