주요 콘텐츠로 건너뛰기
iRobot Roomba 551 Brush Case Replacement
필요한 것
  1. iRobot Roomba 551 Brush Case Replacement, Side Brush: 1 단계, 이미지 1/1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Brush Case Replacement: 2 단계, 이미지 1/1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brush Case Replacement: 3 단계, 이미지 1/1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brush Case Replacement, Bottom Plate: 4 단계, 이미지 1/1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brush Case Replacement: 5 단계, 이미지 1/2 iRobot Roomba 551 Brush Case Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brush Case Replacement: 6 단계, 이미지 1/1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brush Case Replacement, iRobot Roomba 551 Dirt Bin Replacement: 7 단계, 이미지 1/1
    • Push on the dirt bin release button, and pull gently.
  8. iRobot Roomba 551 Brush Case Replacement, Brush Case: 8 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  9. iRobot Roomba 551 Brush Case Replacement: 9 단계, 이미지 1/1
    • Grab the brush case and pull upwards to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John McTigue
회원 가입일: 01/31/14
331 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 회원
CPSU-REGAN-W14S13G14
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 763
