소개
If you are looking to replace the side wheel, it is a slightly lengthier process that can be found here.
This is a simple guide to replace the front wheel of the Roomba, which is a simple grab and lift procedure.
  1. Grab the front wheel housing on the bottom of your Roomba and lift to remove. Grab the front wheel housing on the bottom of your Roomba and lift to remove.
    • Grab the front wheel housing on the bottom of your Roomba and lift to remove.
  2. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  3. Firmly grasp the wheel, and pull to separate from the housing. Firmly grasp the wheel, and pull to separate from the housing.
    • Firmly grasp the wheel, and pull to separate from the housing.
결론
Deborah Newberry
회원 가입일: 2014년 01월 23일
575 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 회원
CPSU-REGAN-W14S13G14
4 회원들
안내서 13개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 674
