소개
This guide explains how to remove the main brush motor from your Roomba.
부품
부품은 필요하지 않습니다.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Push on the dirt bin release button, and pull gently.
    • Push on the dirt bin release button, and pull gently.
  9. Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
    • Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
  10. Grab the brush case and pull upwards to remove.
    • Grab the brush case and pull upwards to remove.
  11. Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach. Repeat for the opposite side of the brush case. Repeat for the opposite side of the brush case.
    • Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
    • Repeat for the opposite side of the brush case.
  12. Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case. Pull off the back of the brush case. Pull off the back of the brush case.
    • Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case.
    • Pull off the back of the brush case.
  13. Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place. Remove the chip from its housing in the blue brush case.
    • Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place.
    • Remove the chip from its housing in the blue brush case.
  14. Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place. Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
    • Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
  15. Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate. Pull out the motor and metal covering.
    • Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate.
    • Pull out the motor and metal covering.
  16. Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board. Gently pull out the circuit board. Gently pull out the circuit board.
    • Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board.
    • Gently pull out the circuit board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John McTigue
회원 가입일: 2014년 01월 31일
331 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 회원
CPSU-REGAN-W14S13G14
4 회원들
안내서 13개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 3,129
