메인 콘텐츠로 스킵하기
소개
This guide explains how to remove the side brush motor from your Roomba.
부품
지정된 부품이 없습니다.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  6. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly. Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
    • Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
  9. Gently pull on motor assembly to remove.
    • Gently pull on motor assembly to remove.
결론
Aaron Jacobs
회원 가입일: 2014년 01월 31일
528 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 회원
CPSU-REGAN-W14S13G14
4 회원들
안내서 13개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 718
