소개
replacing a roomba battery can be an easy task, lets get started fixing the robot.
필요한 것
to get started, remove the screws under the roomba and remove the secondary brush (yellow brush) and then pull up on the bottom panel.
under the castor wheel there is the battery, replace it with a new battery
reseat the bottom panel and screw it back on. screw back on the secondary brush and charge.
거의 끝나갑니다!
congrats! your roomba should be ready to go!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
