주요 콘텐츠로 건너뛰기
iRobot Roomba 560 Fan Replacement
필요한 것
  1. iRobot Roomba 560 Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
  2. iRobot Roomba 560 Fan Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 560 Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
    • Remove the top of the vacuum bin by pulling it straight up.
    • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
  3. iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 560 Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
    • Remove the casing that surrounds the fan by pulling it straight up.
    • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
  4. iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 1개 iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 2개 iRobot Roomba 560 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
    • Remove the casing from the fan and battery component by pulling it straight up.
  5. iRobot Roomba 560 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the small black button from the top of the battery.
    • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
TJ Tamura
회원 가입일: 10/01/15
289 평판
안내서 1개를 작성함
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 회원
CPSU-MANESS-F15S1G22
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 4,855
