주요 콘텐츠로 건너뛰기
iRobot Roomba 560 Side Sweeper Replacement
필요한 것
  1. iRobot Roomba 560 Side Sweeper Replacement, Side Sweeper: 1 단계, 이미지 1/1
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. iRobot Roomba 560 Side Sweeper Replacement: 2 단계, 이미지 1/1
    • Lift the yellow side sweeper, removing it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mairead Blaes
회원 가입일: 10/01/15
825 평판
안내서 4개 작성하였습니다
Cal Poly, Team 1-22, Maness Fall 2015 Cal Poly, Team 1-22, Maness Fall 2015 회원
CPSU-MANESS-F15S1G22
4 회원들
안내서 14개 작성하였습니다
댓글 2개
I need to replace the part on the bottom where the side sweeper screws in. The threads are stripped, I’m guessing, and screw won’t stay in.
Candy Schnurr - 답글
put some hot glue or melt some plastic in the hole before screwing it. you should get the threads back when you unscrew it
Nicolas Sicard -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 23
전체 시간: 1,745
