주요 콘텐츠로 건너뛰기
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: 2 단계, 이미지 1/1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: 3 단계, 이미지 1/2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: 3 단계, 이미지 2/2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: 5 단계, 이미지 1/2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: 5 단계, 이미지 2/2
    • Remove the motor from the blue casing.
결론
Dale Shirley-Potopsingh
회원 가입일: 10/02/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G5
3 회원들
안내서 5개 작성하였습니다
댓글 2개
I changed the motor and still does not work.
Jose - 답글
I changed the motor and still did not work.
Jose - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 730
