소개
The side motor is very important to the overall function of the Roomba, and without it the Roomba would essentially not work. The replacement of it is a easy task and requires very little work.
필요한 것
Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
Lift the external underside cover accordingly.
거의 끝나갑니다!
결론
