주요 콘텐츠로 건너뛰기
iRobot Roomba 595 Pet Series Battery Replacement
필요한 것
  1. iRobot Roomba 595 Pet Series Battery Replacement, Secondary Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Battery Replacement: 2 단계, 이미지 1/1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Unscrew the four 10mm screws on the underside of the Roomba using a Phillips #1 screwdriver.
  4. iRobot Roomba 595 Pet Series Battery Replacement: 4 단계, 이미지 1/1
    • Remove the bottom frame of the device.
  5. iRobot Roomba 595 Pet Series Battery Replacement: 5 단계, 이미지 1/1
    • Grab the green tape attached to the end of the battery and remove the battery from the device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Adrian Martinez Arbolaez
회원 가입일: 10/02/17
221 평판
안내서 1개 작성함
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G5
3 회원들
안내서 5개 작성하였습니다
댓글 2개
Pls, can i charge the roomba directly, because the base is not working??
elie moussa - 답글
Yes I think so, mine can
Big builder - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 62
전체 시간: 5,158
