주요 콘텐츠로 건너뛰기
iRobot Roomba 595 Pet Series Main Brush Replacement
필요한 것
  1. iRobot Roomba 595 Pet Series Main Brush Replacement, Secondary Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Main Brush Replacement: 2 단계, 이미지 1/1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: 3 단계, 이미지 1/2 iRobot Roomba 595 Pet Series Main Brush Replacement, Main Brush: 3 단계, 이미지 2/2
    • Remove the four 10mm screws with a Phillips #1 screwdriver. Gently lift off the external covering for the Roomba's underside.
  4. iRobot Roomba 595 Pet Series Main Brush Replacement: 4 단계, 이미지 1/3 iRobot Roomba 595 Pet Series Main Brush Replacement: 4 단계, 이미지 2/3 iRobot Roomba 595 Pet Series Main Brush Replacement: 4 단계, 이미지 3/3
    • Press lightly on the yellow tabs and lift the cage cover containing the brush.
  5. iRobot Roomba 595 Pet Series Main Brush Replacement: 5 단계, 이미지 1/2 iRobot Roomba 595 Pet Series Main Brush Replacement: 5 단계, 이미지 2/2
    • Lift the brush from the right side and slide it from its container within the Roomba.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dale Shirley-Potopsingh
회원 가입일: 10/02/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 607
