주요 콘텐츠로 건너뛰기
iRobot Roomba 595 Pet Series Wheel Spring Replacement
필요한 것
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 2 단계, 이미지 1/1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 3 단계, 이미지 1/2 iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: 3 단계, 이미지 2/2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 4 단계, 이미지 1/1
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 5 단계, 이미지 1/1
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: 6 단계, 이미지 1/3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 6 단계, 이미지 2/3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: 6 단계, 이미지 3/3
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
결론
Dale Shirley-Potopsingh
회원 가입일: 10/02/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S10-G5, Thompson Fall 2017 USF Tampa, Team S10-G5, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G5
3 회원들
안내서 5개 작성하였습니다
댓글 4개
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - 답글
Where can I get a new spring, mine is missing on the left wheel
emls23 - 답글
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - 답글
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 1,658
