주요 콘텐츠로 건너뛰기
iRobot Roomba 630 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 1/2 iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 2/2
    • Flip the Roomba over so that the wheels are facing upwards.
    • Unscrew the 6 mm screw from the yellow side brush using a Phillips #2 screwdriver.
  2. iRobot Roomba 630 Side Brush Motor Replacement: 2 단계, 이미지 1/2 iRobot Roomba 630 Side Brush Motor Replacement: 2 단계, 이미지 2/2
    • Remove the four 10.1 mm screws from the back cover using a Phillips #2 screwdriver.
    • Lift the back cover off to access the gear box.
  3. iRobot Roomba 630 Side Brush Motor Replacement: 3 단계, 이미지 1/3 iRobot Roomba 630 Side Brush Motor Replacement: 3 단계, 이미지 2/3 iRobot Roomba 630 Side Brush Motor Replacement: 3 단계, 이미지 3/3
    • Remove the three outer 15 mm screws that hold down the gearbox using a Phillips #2 screwdriver.
    • Remove the middle 15 mm screw to release the gearbox using a tri-point Y0 screwdriver.
    • Lift the blue side brush gear box out.
  4. iRobot Roomba 630 Side Brush Motor Replacement: 4 단계, 이미지 1/2 iRobot Roomba 630 Side Brush Motor Replacement: 4 단계, 이미지 2/2
    • Pry the top of the gear box off.
    • Check for debris in the gear box and clean it out if needed.
  5. iRobot Roomba 630 Side Brush Motor Replacement: 5 단계, 이미지 1/3 iRobot Roomba 630 Side Brush Motor Replacement: 5 단계, 이미지 2/3 iRobot Roomba 630 Side Brush Motor Replacement: 5 단계, 이미지 3/3
    • Remove the screws holding the motor in place using a Phillips #2 screwdriver.
    • Pull the old motor out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jabari Baptiste
회원 가입일: 10/03/17
485 평판
안내서 3개 작성하였습니다
USF Tampa, Team S5-G3, Walkup Fall 2017 USF Tampa, Team S5-G3, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G3
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 34
전체 시간: 2,013
