주요 콘텐츠로 건너뛰기
iRobot Roomba 630 Top Bumper Infrared Sensor Replacement
필요한 것
  1. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: 1 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement, Front Sensor: 1 단계, 이미지 2개 중 2개
    • Press the bin button and pull the bin out.
  2. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 2 단계, 이미지 2개 중 2개
    • FIip the device over and unscrew the side brush screw using the Phillips #2 screwdriver.
  3. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 3 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the (4) four back plate screws using the Phillips #2 screwdriver.
    • Lift the back plate off of the device.
  4. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 4 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the screws on the bottom of the front bumper.
  5. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 5 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the device over and lift the front bumper up and off.
    • Lift with care so the sensor wires aren't damaged.
  6. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 6 단계, 이미지 2개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the Roomba back over and unscrew the 2 screws that connect the sensor to the bumper.
  7. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 7 단계, 이미지 3개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 7 단계, 이미지 3개 중 2개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 7 단계, 이미지 3개 중 3개
    • Flip Roomba back over and pry the top cover off.
    • Unscrew the screws to the top plate and lift off.
  8. iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 8 단계, 이미지 3개 중 1개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 8 단계, 이미지 3개 중 2개 iRobot Roomba 630 Top Bumper Infrared Sensor Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers or another tool to push up on the insert while gently pulling the sensor out by its wires.
    • Remove the sensor.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Jeffrey Rook
회원 가입일: 10/03/17
125 평판
안내서 1개를 작성함
USF Tampa, Team S5-G3, Walkup Fall 2017 USF Tampa, Team S5-G3, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G3
4 회원들
안내서 8개를 작성함
4가이드 댓글
Exact same instructions for a Roomba 690. Great guide and much cheaper than sending it in for out of warranty repair at $135 bucks!!!
Jeff Brockway - 답글
Outstanding! I would only add to note position of the 12 top plate screws as they are removed since 3 are smaller/shorter (although not noticeably so) and need to be returned to their exact location. I would not call this difficult. Simply tedious. Thank you very much for the instrucitons.
Linda Marsh - 답글
Thanks for this. Roomba wanted me to send my unit in for repairs costing $130. I bought a replacement Rcon at eBay for $10. Turned out, as others have posted, the red wire was broken! That’s on Roomba!! Works like new, will repair the red wire, and save the rcon for future use.
natenaybore - 답글
This is very helpful! Thank you. In my case, all the 3 wires were thorn from the sensor head. I could resolver them but I can’t tell which is which. Can someone post where the 3 wires connect in the sensor head? There are 3 leads coming out of the sensor head but no insulation left on them so I can match with the correct wire. Much appreciated!
GandaFix - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 10,340
