주요 콘텐츠로 건너뛰기
iRobot Roomba 650 Caster Wheel Replacement
필요한 것
  1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 1개 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 2개
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 1개 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 2개
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: 3 단계, 이미지 1개 중 1개
    • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
  4. iRobot Roomba 650 Caster Wheel Replacement: 4 단계, 이미지 2개 중 1개 iRobot Roomba 650 Caster Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alex Schnorr
회원 가입일: 01/22/15
649 평판
안내서 3개를 작성함
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 회원
CPSU-MANESS-W15S19G7
4 회원들
안내서 6개를 작성함
3가이드 댓글
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - 답글
Worked for my 690 as well.
Luke Oliver - 답글
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,411
