주요 콘텐츠로 건너뛰기
iRobot Roomba 655 Pet Series Battery Replacement
필요한 것
  1. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: 1 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Side Brush: 1 단계, 이미지 2/2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: 2 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Back Panel: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 3 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 3 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Battery Replacement, Removing the Battery: 3 단계, 이미지 3/3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: 4 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Battery Replacement, Battery Contact Points: 4 단계, 이미지 2/2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
결론
다른 12명이 해당 안내서를 완성하였습니다.
Matt Davis
회원 가입일: 01/22/15
1,612 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 67
전체 시간: 12,412
