주요 콘텐츠로 건너뛰기
iRobot Roomba 655 Pet Series Display Replacement
필요한 것
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: 1 단계, 이미지 2개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: 1 단계, 이미지 2개 중 2개
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement: 2 단계, 이미지 2개 중 2개
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: 3 단계, 이미지 2개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: 3 단계, 이미지 2개 중 2개
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: 4 단계, 이미지 3개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement: 4 단계, 이미지 3개 중 2개 iRobot Roomba 655 Pet Series Display  Replacement: 4 단계, 이미지 3개 중 3개
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 5 단계, 이미지 3개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 5 단계, 이미지 3개 중 2개 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: 5 단계, 이미지 3개 중 3개
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: 6 단계, 이미지 3개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement, Display: 6 단계, 이미지 3개 중 2개 iRobot Roomba 655 Pet Series Display  Replacement, Display: 6 단계, 이미지 3개 중 3개
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: 7 단계, 이미지 3개 중 1개 iRobot Roomba 655 Pet Series Display  Replacement: 7 단계, 이미지 3개 중 2개 iRobot Roomba 655 Pet Series Display  Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the display
    • Remove the plastic protectant film from the motherboard
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rhett
회원 가입일: 01/22/15
1,350 평판
안내서 7개를 작성함
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 1,023
