주요 콘텐츠로 건너뛰기
iRobot Roomba 655 Pet Series Front Bumper Replacement
필요한 것
  1. iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: 1 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Front Bumper  Replacement, Front Bumper: 1 단계, 이미지 2/2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. iRobot Roomba 655 Pet Series Front Bumper  Replacement: 2 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: 2 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Front Bumper  Replacement: 2 단계, 이미지 3/3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
결론
Rhett
회원 가입일: 01/22/15
1,329 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 43
전체 시간: 4,196
