주요 콘텐츠로 건너뛰기
iRobot Roomba 655 Pet Series Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3/3
    • First start by removing the two - 6mm screws with your Phillips head #1, that unlock the motor from your Roomba
    • Pull the brush motor out
  2. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 2 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 2 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Gear Box Cover: 2 단계, 이미지 3/3
    • Next, with the same head remove the screw holding the plastic housing together
    • Carefully pry the gear box open by placing a flat head screwdriver in the slot
    • This might be difficult and require some shifting of the screwdriver
  3. iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 3 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 3 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Side Brush Motor Replacement, Motor Removal: 3 단계, 이미지 3/3
    • Removing these two screws will allow you to access the motor (use the same head as before)
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matt Davis
회원 가입일: 01/22/15
1,642 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,665
