소개
You will be removing the yellow side brush and the back panel of your Roomba in order to gain access to other components of your device.
필요한 것
Flip the device over onto its back.
Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
Using a Phillips #1 screwdriver, remove the four screws on the back panel.
Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
거의 끝나갑니다!
결론
