주요 콘텐츠로 건너뛰기
iRobot Roomba 655 Pet Series Front Caster Wheel Replacement
필요한 것
  1. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Side Brush: 1 단계, 이미지 2/2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: 2 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing the Back Panel: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 3 단계, 이미지 1/3 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 3 단계, 이미지 2/3 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removal of Caster Wheel Housing: 3 단계, 이미지 3/3
    • Turn the Roomba upside down, so that the vacuum and wheels are facing the ceiling.
    • Hold the caster wheel housing steady and insert the plastic spudger under the wheel housing.
    • Apply some force to pry the caster wheel straight up out of the device, and remove the caster wheel housing from the Roomba.
  4. iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: 4 단계, 이미지 1/2 iRobot Roomba 655 Pet Series Front Caster Wheel Replacement, Removing Wheel From Rotating Housing: 4 단계, 이미지 2/2
    • Firmly hold the caster wheel housing, and remove the caster wheel from its setting.
    • Clean the caster wheel with soap and water.
    • Once the caster wheel is clean and thoroughly dried, repeat the process in reverse order to reinstall the caster wheel back to the Roomba.
결론
To reassemble the robot, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Rhett
회원 가입일: 01/22/15
1,329 평판
안내서 7개 작성하였습니다
Cal Poly, Team 21-20, Maness Winter 2015 Cal Poly, Team 21-20, Maness Winter 2015 회원
CPSU-MANESS-W15S21G20
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 37
전체 시간: 5,908
