주요 콘텐츠로 건너뛰기
iRobot Roomba 690 Drive Wheels Replacement
필요한 것
  1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: 1 단계, 이미지 1/1
    • Place the Roomba upside down so that the wheels and brushes are facing upward.
  2. iRobot Roomba 690 Drive Wheels Replacement: 2 단계, 이미지 1/3 iRobot Roomba 690 Drive Wheels Replacement: 2 단계, 이미지 2/3 iRobot Roomba 690 Drive Wheels Replacement: 2 단계, 이미지 3/3
    • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
    • Remove the spinning brush from the vacuum.
  3. iRobot Roomba 690 Drive Wheels Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
    • They are labeled with triangular arrows next to them on the cover.
  4. iRobot Roomba 690 Drive Wheels Replacement: 4 단계, 이미지 1/1
    • Lift the bottom cover up from the rest of the Roomba.
  5. iRobot Roomba 690 Drive Wheels Replacement: 5 단계, 이미지 1/3 iRobot Roomba 690 Drive Wheels Replacement: 5 단계, 이미지 2/3 iRobot Roomba 690 Drive Wheels Replacement: 5 단계, 이미지 3/3
    • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
  6. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: 6 단계, 이미지 1/2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: 6 단계, 이미지 2/2
    • Each drive wheel is labeled left and right.
    • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
    • Remove the drive wheels from the vacuum.
결론
John Galvin
회원 가입일: 03/23/22
584 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-1, Botvin Spring 2022 UMass Dartmouth, Team 1-1, Botvin Spring 2022 회원
UMASSD-BOTVIN-S22S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 16
30일 전: 23
전체 시간: 455
