주요 콘텐츠로 건너뛰기
iRobot Roomba 770 Filter Replacement
  1. iRobot Roomba 770 Filter Replacement, Filter: 1 단계, 이미지 1/1
    • Orient the Roomba so that the "Clean Button" is up, and so that the words are right side up.
    • Push down on the large button on the part of the Roomba that is closest to you. Pull the back of the Roomba (the dust bin) out.
  2. iRobot Roomba 770 Filter Replacement: 2 단계, 이미지 1/3 iRobot Roomba 770 Filter Replacement: 2 단계, 이미지 2/3 iRobot Roomba 770 Filter Replacement: 2 단계, 이미지 3/3
    • Take the dust bin and orient it so that the curved part is facing away and the clear side is facing up.
    • Push the small yellow tab inward, and swing it out toward you.
  3. iRobot Roomba 770 Filter Replacement: 3 단계, 이미지 1/2 iRobot Roomba 770 Filter Replacement: 3 단계, 이미지 2/2
    • Push up on the yellow tabs on the yellow filters, and pull both filters out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Horvath
회원 가입일: 10/05/16
444 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 967
