주요 콘텐츠로 건너뛰기
iRobot Roomba 770 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 770 Side Brush Motor Replacement, Battery: 1 단계, 이미지 2개 중 1개 iRobot Roomba 770 Side Brush Motor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the Roomba over so that the wheels are facing up and the dust tray is closest to you.
    • Using the J1 Phillips screwdriver, locate and unscrew the two 11mm phillips screws above the brushes on the battery panel.
    • Remove the plastic plate from the battery box.
  2. iRobot Roomba 770 Side Brush Motor Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 770 Side Brush Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the 2 green tabs on the left and right of the big yellow battery.
    • Grab the tabs with your hands and lift straight upward.
  3. iRobot Roomba 770 Side Brush Motor Replacement, Side Brush Motor: 3 단계, 이미지 1개 중 1개
    • Using the J1 Philips Screwdriver, remove the 15.5 mm screw located in the center of the side brush.
    • Remove the brush by pulling upwards.
    • Do not lean directly over the brush when attempting to remove. Removing the brush requires a firm pull and may release suddenly.
  4. iRobot Roomba 770 Side Brush Motor Replacement: 4 단계, 이미지 2개 중 1개 iRobot Roomba 770 Side Brush Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Using the J1 Philips Screwdriver, remove the two 15.5 mm screws located on the bottom of the plate covering the bottom of the roomba.
    • Lift upwards to remove the bottom plate.
  5. iRobot Roomba 770 Side Brush Motor Replacement: 5 단계, 이미지 2개 중 1개 iRobot Roomba 770 Side Brush Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Using the J1 Philips Screwdriver, remove the two gold 15.5 mm screws located on the blue plastic module the side brush had previously been attached too.
    • Lift the blue module upwards. The module contains the motor for the side brush.
결론
작성자
2다른 기여자 명과 함께
Ashley Woods
회원 가입일: 10/06/16
365 평판
안내서 1개를 작성함
Cal Poly, Team 15-3, Livingston Fall 2016 Cal Poly, Team 15-3, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 2,881
