소개
This guide will go over how to clean or replace the wheels in your iRobot Roomba 805. If you plan on replacing either wheel you can get a new one from iRobot. A Phillips head screwdriver is needed to follow this guide.
필요한 것
Remove the battery panel, then remove the two screws behind the wheels, and lift the bottom panel apart from the rest of the device.
거의 끝나갑니다!
결론
