주요 콘텐츠로 건너뛰기
iRobot Roomba 860 Bumper & Bumper Sensor Replacement
필요한 것
  1. iRobot Roomba 860 Bumper & Bumper Sensor Replacement, Bumper & Bumper Sensor: 1 단계, 이미지 1/2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement, Bumper & Bumper Sensor: 1 단계, 이미지 2/2
    • Place Roomba flat on table with iRobot text upside down and closest to you.
    • Detach the clips on the bumper.
    • Flip Roomba so that the bottom side is facing up and you can access bottom screws on bumper.
  2. iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 2 단계, 이미지 1/2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the two screws.
  3. iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 3 단계, 이미지 1/2 iRobot Roomba 860 Bumper & Bumper Sensor Replacement: 3 단계, 이미지 2/2
    • Once the screws are removed, the wire will detach from the bumper and sensor with very light force.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Danny Andrade
회원 가입일: 11/01/18
121 평판
안내서 1개 작성함
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G5
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Very good directions for disassembly. Can you add specific instructions for re-assembly?
If you have any suggestions for getting the main part of the bumper back on, that would be helpful. It was very challenging to get that part reattached to the chassis. There is a tab at each end of the main part of the bumper, and it was challenging to get them into their respective slots. It required a lot of pushing and pulling and compressing of the main bumper part, and although the tabs finally went where they were supposed to go, I’m not sure what I did to get them there.
S Butler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 22
전체 시간: 1,688
