주요 콘텐츠로 건너뛰기
iRobot Roomba 860 Debris Extractor Cleaning / Replacement
필요한 것
  1. iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: 1 단계, 이미지 1/2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement, Debris Extractors: 1 단계, 이미지 2/2
    • To remove the debris extractor, first begin by removing and emptying the trash bin.
    • Push down and pull out on the silver button located on the top of the Roomba in the back.
    • The trash bin should then slide out.
  2. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 2 단계, 이미지 1/2 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 2 단계, 이미지 2/2
    • With the Roomba upside down, locate the two yellow buttons by the extractor.
    • To open the flap holding the extractos in place, pinch the two yellow buttons together towards the center and pull up on the flap at the same time
  3. iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 3 단계, 이미지 1/3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 3 단계, 이미지 2/3 iRobot Roomba 860 Debris Extractor Cleaning / Replacement: 3 단계, 이미지 3/3
    • Once the flap is open, grab the yellow end of the dark gray extractor and pull up slightly.
    • After lifting it up about an inch, pull it out towards one of the side wheels.
    • The extractor should slide out with ease. Repeat the same procedure for the light gray debris extractor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Murphy
회원 가입일: 03/02/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 회원
USFT-CAGLE-S17S13G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 1,453
