주요 콘텐츠로 건너뛰기
iRobot Roomba 860 Filter Replacement
  1. iRobot Roomba 860 Filter Replacement, Filter: 1 단계, 이미지 1/3 iRobot Roomba 860 Filter Replacement, Filter: 1 단계, 이미지 2/3 iRobot Roomba 860 Filter Replacement, Filter: 1 단계, 이미지 3/3
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
    • Press the large button on the Roomba that is located closest to you.
    • Pull towards you to remove dust bin.
    • Now place dust bin flat with the large button towards you.
  2. iRobot Roomba 860 Filter Replacement: 2 단계, 이미지 1/2 iRobot Roomba 860 Filter Replacement: 2 단계, 이미지 2/2
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right.
    • Now lift red plastic cover to begin removing the filter.
  3. iRobot Roomba 860 Filter Replacement: 3 단계, 이미지 1/2 iRobot Roomba 860 Filter Replacement: 3 단계, 이미지 2/2
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
결론
Stephen Yezukevicz
회원 가입일: 11/06/18
193 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 323
