주요 콘텐츠로 건너뛰기
iRobot Roomba 860 Main Brush Replacement
  1. iRobot Roomba 860 Main Brush Replacement, Main Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down and so that the side brush is closest to you and on the right side.
  2. iRobot Roomba 860 Main Brush Replacement: 2 단계, 이미지 1/3 iRobot Roomba 860 Main Brush Replacement: 2 단계, 이미지 2/3 iRobot Roomba 860 Main Brush Replacement: 2 단계, 이미지 3/3
    • Using the two yellow tabs, pinch them towards one another.
    • Carefully lift the door up with the hinge away from you.
  3. iRobot Roomba 860 Main Brush Replacement: 3 단계, 이미지 1/3 iRobot Roomba 860 Main Brush Replacement: 3 단계, 이미지 2/3 iRobot Roomba 860 Main Brush Replacement: 3 단계, 이미지 3/3
    • Pull out the main brush, similar to removing a set of batteries from a remote.
    • Repeat to remove both of the main brushes.
결론
Stephen Yezukevicz
회원 가입일: 11/06/18
193 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 535
