주요 콘텐츠로 건너뛰기
iRobot Roomba 860 Side Brush Replacement
필요한 것
  1. iRobot Roomba 860 Side Brush Replacement, Side Brush: 1 단계, 이미지 1/1
    • Start by locating the yellow side brush on the underside of the iRobot Roomba 860 near the front of the device.
  2. iRobot Roomba 860 Side Brush Replacement: 2 단계, 이미지 1/1
    • Using a Philips #2 Point Screwdriver, remove the screw located in the center of the brush.
  3. iRobot Roomba 860 Side Brush Replacement: 3 단계, 이미지 1/2 iRobot Roomba 860 Side Brush Replacement: 3 단계, 이미지 2/2
    • Pull up on the side brush and it should slide off, free of the motor shaft.
    • Remove any debris that could be preventing the side brush from spinning and/or replace the side brush.
결론
Ryan Murphy
회원 가입일: 03/02/17
446 평판
안내서 4개 작성하였습니다
USF Tampa, Team S13-G5, Cagle Spring 2017 USF Tampa, Team S13-G5, Cagle Spring 2017 회원
USFT-CAGLE-S17S13G5
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
What to do if the screw head is broken off? Thanks
Linda - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 927
