주요 콘텐츠로 건너뛰기
iRobot Roomba 870 Bumper Sensor Replacement
필요한 것
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 1 단계, 이미지 2개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: 1 단계, 이미지 2개 중 2개
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0 mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: 2 단계, 이미지 3개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 2 단계, 이미지 3개 중 2개 iRobot Roomba 870  Bumper Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 3.5 mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 870  Bumper Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two remaining 3.5 mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: 4 단계, 이미지 3개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 4 단계, 이미지 3개 중 2개 iRobot Roomba 870  Bumper Sensor Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the ten 3 mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: 5 단계, 이미지 2개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: 6 단계, 이미지 3개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 6 단계, 이미지 3개 중 2개 iRobot Roomba 870  Bumper Sensor Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 3 mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: 7 단계, 이미지 2개 중 1개 iRobot Roomba 870  Bumper Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob Lindberg
회원 가입일: 04/19/17
449 평판
안내서 1개를 작성함
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G3
4 회원들
안내서 10개를 작성함
3가이드 댓글
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - 답글
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - 답글
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 8,765
