주요 콘텐츠로 건너뛰기
iRobot Roomba 870 Battery Replacement
필요한 것
  1. iRobot Roomba 870 Battery Replacement, Battery: 1 단계, 이미지 1/2 iRobot Roomba 870 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: 2 단계, 이미지 1/3 iRobot Roomba 870 Battery Replacement: 2 단계, 이미지 2/3 iRobot Roomba 870 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
결론
Follow the steps in reverse order for reassembly.
다른 2명이 해당 안내서를 완성하였습니다.
Vitek Harvey
회원 가입일: 04/26/17
149 평판
안내서 1개 작성함
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 29
전체 시간: 3,376
