소개
This guide will teach you how to access, remove, and replace your iRobot Roomba 870 battery.
필요한 것
To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
거의 끝나갑니다!
Follow the steps in reverse order for reassembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
