소개
These wheels control the main movement of the device. Since it is one of the main parts used, the tires of the wheel may get worn, debris may get caught inside, or the wheel may just need to be replaced from overuse.
필요한 것
While the Roomba is upside down, remove the 4.0mm screw surrounding the side brush using a Phillips #2 screwdriver.
Remove the brush.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
