주요 콘텐츠로 건너뛰기
iRobot Roomba 870 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3개 중 2개 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3개 중 3개
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: 2 단계, 이미지 2개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: 3 단계, 이미지 2개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement: 3 단계, 이미지 2개 중 2개
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 3개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 3개 중 2개 iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 3개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 3개 중 2개 iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 3개 중 1개 iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 3개 중 2개 iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Karthik Padmanabhan
회원 가입일: 04/17/17
175 평판
안내서 1개를 작성함
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G3
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 48
전체 시간: 3,925
