주요 콘텐츠로 건너뛰기
iRobot Roomba 870 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 1/3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 2/3 iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3/3
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: 2 단계, 이미지 1/2 iRobot Roomba 870 Side Brush Motor Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: 3 단계, 이미지 1/2 iRobot Roomba 870 Side Brush Motor Replacement: 3 단계, 이미지 2/2
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 1/3 iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 2/3 iRobot Roomba 870 Side Brush Motor Replacement: 4 단계, 이미지 3/3
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 1/3 iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 2/3 iRobot Roomba 870 Side Brush Motor Replacement: 5 단계, 이미지 3/3
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 1/3 iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 2/3 iRobot Roomba 870 Side Brush Motor Replacement: 6 단계, 이미지 3/3
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Karthik Padmanabhan
회원 가입일: 04/17/17
175 평판
안내서 1개 작성함
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S14G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 38
전체 시간: 3,585
