주요 콘텐츠로 건너뛰기
iRobot Roomba 880 Battery Replacement
필요한 것
  1. iRobot Roomba 880 Battery Replacement, Battery: 1 단계, 이미지 1/2 iRobot Roomba 880 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: 3 단계, 이미지 1/2 iRobot Roomba 880 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the battery using the green tabs on either side of the battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Frances Belcher
회원 가입일: 04/18/17
420 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G4
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 38
전체 시간: 4,625
