주요 콘텐츠로 건너뛰기
iRobot Roomba 880 Cleaning Head Replacement
필요한 것
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 1 단계, 이미지 1/3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 1 단계, 이미지 2/3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: 1 단계, 이미지 3/3
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: 2 단계, 이미지 1/2 iRobot Roomba 880 Cleaning Head Replacement, Side Brush: 2 단계, 이미지 2/2
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: 3 단계, 이미지 1/1
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: 4 단계, 이미지 1/2 iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: 4 단계, 이미지 2/2
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: 5 단계, 이미지 1/2 iRobot Roomba 880 Cleaning Head Replacement: 5 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 6 단계, 이미지 1/3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 6 단계, 이미지 2/3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: 6 단계, 이미지 3/3
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Allie Ahern
회원 가입일: 04/27/17
130 평판
안내서 1개 작성함
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 2,245
